5th April 2021, 06:04 PM
#11
So the specs say the bearing ID should be 41.275 so that one is under by quite a bit really.
Yeah it could have been worn or possibly adjustment has caused it. It could have also been the contamination that has allowed a roller or 2 to grab the inner race and spin it around. I think this has been from outside contamination maybe through the locking hub. It would be very hard for the LMM grease to get into the wheel bearing area.
The spindle isn't great and would be best if it was replaced in my opinion.
The Following User Says Thank You to nissannewby For This Useful Post:
MudRunnerTD (5th April 2021)
5th April 2021 06:04 PM
5th April 2021, 06:05 PM
#12
Should only really use the LMM in the CV. Use your other red grease for everything else.
5th April 2021, 06:51 PM
#13
Moderator
nissannewby
Thanks mate that makes sense as I stand here ans look at the spindle I agree there is completely separation between the CV and the wheel bearings. If the spindle appears to be the right diameter coyld I not just clean it up and on? The thread is in perfect condition and that section should allow a bearing to sit there as designed. Do you think it is weakened? They are Drug money to buy is all.
Check out my Toy -->
Rogue Dung Beetle
5th April 2021, 07:00 PM
#14
Yeah you could attempt to clean it up with some wet n dry. I would be measuring with a mic if possible. Then just pay close attention to sealing it all up when re assembling to hopefully prevent anymore ingress. Even silicon or thread sealant on bolts.
