Results 1 to 4 of 4
Thread: Blown ZD30 CRD
    Mar 2021
    Blown ZD30 CRD
    Hi my son has just blown his 2012 ZD30 CRD. I think it has blown a hole in a piston. What is best course of action 1. strip and repair engine myself 2. get a second hand engine 3. buy a rebuilt engine. Any help is much appreciated.
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    If the engine turns over a compression test will tell you if that is the problem, and not an injector or something else.
    The master farter
    mudski's Avatar
    461 Post(s)
    Very unusual for a ZD of this age to blow a hole in the piston. As mudnut said, get a comp test done, Could be just a turbo or injector, or pump. What makes yous think its a holed piston? What is happening?
    Expert Truckus's Avatar
    Feb 2021
    Central Coast NSW
    G'day and welcome.
    As the fella have said, blowing a hole in a piston crown is extremely rare, so likely something else going on.
    Plus one again for the compression test.
    If the engine is screwed, well go bullet proof https://www.patrol4x4.com/threads/gu...ersion.400169/
    You tell 'em Rocket Rod
    2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
