28th March 2021, 05:38 PM
Blown ZD30 CRD
Hi my son has just blown his 2012 ZD30 CRD. I think it has blown a hole in a piston. What is best course of action 1. strip and repair engine myself 2. get a second hand engine 3. buy a rebuilt engine. Any help is much appreciated.
28th March 2021 05:38 PM
28th March 2021, 05:55 PM
If the engine turns over a compression test will tell you if that is the problem, and not an injector or something else.
29th March 2021, 07:11 AM
Very unusual for a ZD of this age to blow a hole in the piston. As mudnut said, get a comp test done, Could be just a turbo or injector, or pump. What makes yous think its a holed piston? What is happening?
29th March 2021, 03:41 PM
G'day and welcome.
As the fella have said, blowing a hole in a piston crown is extremely rare, so likely something else going on.
Plus one again for the compression test.
If the engine is screwed, well go bullet proof https://www.patrol4x4.com/threads/gu...ersion.400169/
You tell 'em Rocket Rod
2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
