Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Lithium batteries
    Shit hot Rossco you are smashing it! You've seriously got the perfect "tough tourer" setup.
    175 Post(s)
    So ended up after a huge amount of deliberation getting an ITechworld 120x which is a 107AH. It'l be way overkill for what what I need but what the hey it will be awesome I reckon. . Was looking at the Vlotax which are pretty cheap and also Renogy which are a lot more highly regarded but happy to spend more on an Australian product for the Itech. In the end the main thing was the temperature range of the BMS and operation of the battery with most around 0 to 50 degrees which isn't bad but who knows what happens in ther snow or in cab can easily get up there. . Can't remember what the ITech was but looks like it should be good on paper and sure it will IRL lol. . .
    Perfect fit behind drawers. .
    Just waiting for tray then can start putting it all together. .
    Congrats Rossco! Same unit as I have...
    Watch in awe how long it lasts... ENjoy!
    Rossco (13th April 2021)
  5. #13
    192 Post(s)
    Yeah cheers for posting up Hodgey, they really do tick all the boxes, can't wait to see how she goes
  6. The Following User Says Thank You to Rossco For This Useful Post:
    Hodge (13th April 2021)
  7. #14
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    A bit of info on their real world under-bonnet performance here. It is not a Patrol, but still not bad information.
  8. The Following User Says Thank You to Brissieboy For This Useful Post:
    MB (21st May 2021)
  9. #15
    472 Post(s)
    Crikey, that definitely appears Lithium heat issues Mythbusting for sure BB Mate
    Makes me nuffy wonder if they’re not suitable also for heavy winching work possibly too
    Thinking aloud they might not appreciate huge losses over such a short period like my new 170A AGM Kickass house tray battery warned of warranty voiding IIRC on instructions?
  10. #16
    Jan 2014
    Perth Wanneroo
    My set up is quite different.
    I have two DCS (Deep Cycle Systems) 12V 200Ah Slimline batteries.
    Because of the overall capacity, lithium benefits (such as rapid charging) and monitoring system they are just being run in parallel.
    The charging system is managed by a smart programmable control unit which includes alternator temp monitoring. They are charged by a 320 max/240 idle amp alternator which they will accept full charge rate from until it potentially overheats.
    There is a MOTEC PDM unit that many accessories such as fridges run off which has a programmable low voltage cutoffs
    Batteries are mounted behind the cab and under the tray
    We actually pulled them apart to strengthen the internal mounting too
  11. The Following 2 Users Say Thank You to Figjam For This Useful Post:
    MB (25th May 2021), Stropp (25th May 2021)
  12. #17
    472 Post(s)
    Which and what Lithium’s/AGM’s can currently handle getting half their guts truly sucked out in under 2-3 Minutes Please Folks ?
  13. #18
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    itechworld are currently offering 20% off everything. Their 120X lithium is now at $780 instead of $975. Discount code is 'FB20'.
  14. The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
    Hodge (5th June 2021), MB (5th June 2021)
  15. #19
    Expert Mickhead's Avatar
    Oct 2019
    Itechworld are good, but they are not aussie made as some may think. They may have aussie mined contents in them. A bit overpriced, and wont easily refund you the difference if their batteries go on sale a day after you buy one.All are made in china.
    Look at numbers like max continuous current draw, amp hours, max peak current draw, max charging current, and if you want a starting battery, CCA. Some batteries can provide huge CCA for emergency starting.
    Lanplus on ebay in west heidelberg is a good seller, have been there and seen they fully test their batteries to make sure they are close to advertised capacity.
  16. The Following 5 Users Say Thank You to Mickhead For This Useful Post:
    Cremulator (6th June 2021), Hodge (6th June 2021), MB (5th June 2021), PeeBee (5th June 2021), Rossco (5th June 2021)
