Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: EDS engine data scan vs Scanguage II
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Hey all
    Just wanting feedback from anyone that is running or has heard about EDS data scan. I was on berrima diesels website and noticed that they don't appear to sell scanguage anymore? But it appears that this new product can do everything plus more (?) and for only $199
    Any feedback would be appreciated
    http://www.berrimadiesel.com/eshop/e...tag=Monitoring
    Advanced Clarkie's Avatar
    Dec 2014
    Kellyville, NSW
    If it does what it says I'd be keen.
    Dave
    _____________________________________________
    2014 Nissan Patrol ST Titanium Auto - I'm new be nice
    Patrol Guru
    NT
    As well as scan gauge, look up ultra gauge. Similar, but slightly different features, and different shape.
    Legendary happygu's Avatar
    Quote Originally Posted by P4trol View Post
    Do you have the Ultagauge P4trol?
    Mic
    Mar 2011
    14 Post(s)
    Interested to get your feedback as well if you have this. From what I can see on their website, Ultraguage doesn't appear to offer boost gauge for CRD models... Is this correct?
    175 Post(s)
    I don't think any of them can mate. The only thing they do read is the MAP. I don't know how accurate this is though , as my SG 2 and my boost gauge readings are miles apart...
    Bacho86 (12th January 2015)
    Unafordable
    4 Post(s)
    MAP = Manifold Absolute Pressure which means it reads boost pressure + atmospheric pressure (usually add another 14.5 psi) hence the difference.
    MAP is more important anyway, thats why the ECU monitors MAP not Boost
    MAF x MAP X Compression Ratio = Cylinder Pressure = How much Oxygen is there to mix with Diesel and blow up
    Boost X Compression Ratio = an arbitary number that may or may not be good or bad or somewhere in between
  11. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    Bacho86 (12th January 2015), Bigcol (4th August 2015), Hodge (12th January 2015)
  12. #9
    175 Post(s)
    Quote Originally Posted by Rumcajs View Post
    Thanks for clarifying this. It always puzzled me.
    The easiest way to look at it is this I reckon...
    The ECU is doing two main jobs with the MAF and MAP info,
    - manipulating boost so you get as much air in there as possible but don't exceed the max Cylinder Pressure on compression
    - working out how much Oxygen is in there so it doesn't overfuel
    32 PSI MAP in a 20:1 compression ratio is 640 PSI Cylinder pressure no matter what the atmospheric pressure is at the time so you can use that number as a hard limit
    16 PSI Boost in a 20:1 compression ratio is 320 PSI plus whatever atmospheric pressure is at the time which is a soft number so you may be over or under boosting.
    That is why a Dawes valve is a bit of a compromise, it cannot compensate for changes in atmospheric pressure.
