Results 1 to 4 of 4
Thread: nats issue 0?
    Beginner bogan@bonogin's Avatar
    Mar 2021
    gold coast
    nats issue 0?
    just wondering if anyone actually knows what fault codes 1401 & 1403 are ,? I know its nats related but cant find it in manual or old threads . does anyone had a complete list of all fault codes for zd30 y61 ? help would be wonderful
    I comfort the disturbed :& disturb the comfortable !
    Expert Truckus's Avatar
    Feb 2021
    Central Coast NSW
    Off memory 1401 to 1408 are NATS related,
    Fault codes
    0087 Fuel Rail System (Pressure too low)
    0089 Air in fuel System
    0102 Mass Air Flow Sensor
    0103 Coolant temp sender
    0104 Vehicle speed sensor
    0203 Throttle pedal switch
    0208 Overheating Fault (Cooling Fan control)
    0234 Turbo Over boost
    0301 Engine ECU
    0402 Fuel temperature sensor
    0403 Throttle pedal position sensor
    0406* Intake air volume VNC system
    0407 Crankshaft position sensor
    0502* Battery voltage
    0504 Auto Trans communication line
    0505 No faults detected
    0660 Intake Manifold Tuning Valve Control Circuit (Bank 1)
    0701 Injection Pump – cam ring position sensor
    0702 Injection Pump – TDC pulse sensor
    0703 Injection Pump communication line
    0704 Injection Pump – spill valve
    0705 Injection Pump – Circuit malfunction, poor fuel quality, Pump Control Unit Failure
    0706 Injection Pump –spill valve
    0707 Injection Pump injection timing control
    0802 Engine ECU (Barometric Pressure Sensor)
    0804* Engine ECU
    0807 Stop lamp switch/circuit
    0901 Engine ECU (calculation malfunction)
    0902 Engine ECU relay (incorrect voltage from relay to ECU
    0903* Engine ECU (internal signal processing malfunction)
    0905 Turbo Pressure (Intake air pressure sensor)
    1003 EGR volume control valve
    1004 Injection Pump – fuel cut out system
    1401 NATS locked
    1402 NATS locked
    1403 NATS locked
    1404 NATS locked
    1405 NATS locked
    1406 NATS locked
    1407 NATS locked
    1408 NATS locked
    * These codes do not illuminate the Check Engine warning lamp.
    Have a read here too https://www.patrol4x4.com/threads/ur...e-1401.128146/
    as sometimes if the battery voltage drops below 10.3 V, that can cause these to pop up, but plenty of other things to try mentioned in that topic.
    2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
  4. The Following 2 Users Say Thank You to Truckus For This Useful Post:
    bogan@bonogin (26th March 2021), MudRunnerTD (5th April 2021)
  5. #3
    Mar 2021
    gold coast
    yes but does anyone actually know what 1401 & 1403 are for or does someone know how to bypass nats alltogether ??????????
  6. #4
    Patrol God Stropp's Avatar
    31 Post(s)
    Quote Originally Posted by bogan@bonogin View Post
    Check this http://www.nissanpatrol.com.au/forum...53-MudRunnerTD
