25th March 2021, 11:27 AM
nats issue 0?
just wondering if anyone actually knows what fault codes 1401 & 1403 are ,? I know its nats related but cant find it in manual or old threads . does anyone had a complete list of all fault codes for zd30 y61 ? help would be wonderful
I comfort the disturbed :& disturb the comfortable !
25th March 2021 11:27 AM
25th March 2021, 02:52 PM
Off memory 1401 to 1408 are NATS related,
Fault codes
0087 Fuel Rail System (Pressure too low)
0089 Air in fuel System
0102 Mass Air Flow Sensor
0103 Coolant temp sender
0104 Vehicle speed sensor
0203 Throttle pedal switch
0208 Overheating Fault (Cooling Fan control)
0234 Turbo Over boost
0301 Engine ECU
0402 Fuel temperature sensor
0403 Throttle pedal position sensor
0406* Intake air volume VNC system
0407 Crankshaft position sensor
0502* Battery voltage
0504 Auto Trans communication line
0505 No faults detected
0660 Intake Manifold Tuning Valve Control Circuit (Bank 1)
0701 Injection Pump – cam ring position sensor
0702 Injection Pump – TDC pulse sensor
0703 Injection Pump communication line
0704 Injection Pump – spill valve
0705 Injection Pump – Circuit malfunction, poor fuel quality, Pump Control Unit Failure
0706 Injection Pump –spill valve
0707 Injection Pump injection timing control
0802 Engine ECU (Barometric Pressure Sensor)
0804* Engine ECU
0807 Stop lamp switch/circuit
0901 Engine ECU (calculation malfunction)
0902 Engine ECU relay (incorrect voltage from relay to ECU
0903* Engine ECU (internal signal processing malfunction)
0905 Turbo Pressure (Intake air pressure sensor)
1003 EGR volume control valve
1004 Injection Pump – fuel cut out system
1401 NATS locked
1402 NATS locked
1403 NATS locked
1404 NATS locked
1405 NATS locked
1406 NATS locked
1407 NATS locked
1408 NATS locked
* These codes do not illuminate the Check Engine warning lamp.
Have a read here too https://www.patrol4x4.com/threads/ur...e-1401.128146/
as sometimes if the battery voltage drops below 10.3 V, that can cause these to pop up, but plenty of other things to try mentioned in that topic.
2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
The Following 2 Users Say Thank You to Truckus For This Useful Post:
bogan@bonogin (26th March 2021), MudRunnerTD (5th April 2021)
5th April 2021, 03:23 PM
yes but does anyone actually know what 1401 & 1403 are for or does someone know how to bypass nats alltogether ??????????
11th April 2021, 12:25 PM
bogan@bonogin
Check this http://www.nissanpatrol.com.au/forum...53-MudRunnerTD
