Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 54
Thread: Need new start battery for GU - are the Optima yellow tops still worth it ?
  1. #41
    472 Post(s)
    FWIW: I too years ago was under the impression that nearly but not quite 1,000 CCA Optima Red’s & Odyssey Red’s were the Bee’s Knees for in the day 2.5hp Warn High Mount Comp winches
    Big horsepower race crankers like reds get destroyed by winch sucking adventures and your new D31A weapon has the best of both worlds John with circa 900 CCA and a capability of Deep Sucking Cycle TOUGH
    jff45 (4th April 2021)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    It always started well when the old battery was charged but now it's really instant.
    John
  5. The Following User Says Thank You to jff45 For This Useful Post:
    MB (4th April 2021)
  6. #43
    472 Post(s)
    You’ve made a Top Purchase there John Mate!
    Just ran my new GQ D31 parallel pairs through a full maintenance/health check after completely pushing them to their limits down in Tassie
    They’ve thankfully made it all the way to ‘Stage 7- Happy Maintenance Trickle’ (NO stuffed coils/plates)
    GREAT BATTERIES
  7. The Following User Says Thank You to MB For This Useful Post:
    jff45 (10th April 2021)
  8. #44
    Morayfield, QLD
    Finally got back to this battery installation to get it finished. Wasn’t really sure how to make a cover for the positive terminal and settled on some red acrylic that could be shaped a bit with the heat gun.
    A 3mm stainless screw fits nicely into the gap to hold it on.
    The cutout where the 8mm thread is showing is to clamp the battery charger when needed.
    John
  9. The Following 3 Users Say Thank You to jff45 For This Useful Post:
    Cremulator (8th May 2021), Hodge (8th May 2021), MB (11th May 2021)
  10. #45
    175 Post(s)
    Very very neat John.
    Love those terminals!!
  11. The Following User Says Thank You to Hodge For This Useful Post:
    jff45 (8th May 2021)
  12. #46
    174 Post(s)
    Nice Job!
    I like those terminals too, although perhaps the 4 bolt version the same seller has might suit me. Can you tell a bit more about the making of the +ve terminal cover? Just flat acrylic sheet over the top? How is it attached? Where did you get the acrylic?
  13. #47
    Morayfield, QLD
    It’s rolled under the flat of the factory cable on the engine side and screwed down by the small screw you see there. Didn’t have to drill, the screw tightened nicely in the space there.
    Just heated the end to roll it under. I’ll take a pic of the end tomorrow.
    Acrylic sheet here:
    https://www.ebay.com.au/itm/Coloured....m46890.l49286
    John
  14. The Following User Says Thank You to jff45 For This Useful Post:
    MB (11th May 2021)
  15. #48
    Morayfield, QLD
    John
  16. The Following 3 Users Say Thank You to jff45 For This Useful Post:
    Cremulator (10th May 2021), MB (11th May 2021), RickGQ (10th May 2021)
  17. #49
    Jun 2018
    24 Post(s)
    Top notch really nice work.
    This is something I just wouldn't have thought of doing. Thanks for sharing.
  18. The Following User Says Thank You to Cremulator For This Useful Post:
    jff45 (10th May 2021)
  19. #50
    175 Post(s)
    In need of a new battery. I am aiming for the d31a.
    I noticed the M variant D31M is identical to D31A Yellow top. But it has a bonus threaded hole to attach things to.
    Is there a reason you didn't go for that one John???
