23rd March 2021, 11:15 AM
GQ Y60 Speedo
Hi all ive been after a 5 bolt 12 volt dial they are like hens teeth has anyone tried to replace these with a different type of speedo dial that works or have one for sale
23rd March 2021 11:15 AM
23rd March 2021, 12:09 PM
What is the problem with your unit? It could be as simple a fix as a dry solder joint.
27th March 2021, 10:03 AM
Hi mudnut your'e right first i changed a ceramic filter which i got from Taiwan that had corroded then replaced 2 capacitors and a dry joint on a resistor and it worked for about an hour then back to the jumping and flickering so out it came for the 6th time and thought i would resolder the motor connections 4 joints and presto it worked i then used the dash pot the adjust the speedo to a gps speedo on my phone now i can get a warrant and save alot of bucks if i could find one ill just say keep playing with it you might be lucky to fix it Cheers
27th March 2021, 10:10 AM
Wreckers or Gumtree. Try Patrolapart or Readies4x4 Bendigo.
29th March 2021, 09:48 AM
