Results 1 to 5 of 5
Thread: GQ Y60 Speedo
    Oct 2018
    GQ Y60 Speedo
    Hi all ive been after a 5 bolt 12 volt dial they are like hens teeth has anyone tried to replace these with a different type of speedo dial that works or have one for sale
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    What is the problem with your unit? It could be as simple a fix as a dry solder joint.
    Oct 2018
    Hi mudnut your'e right first i changed a ceramic filter which i got from Taiwan that had corroded then replaced 2 capacitors and a dry joint on a resistor and it worked for about an hour then back to the jumping and flickering so out it came for the 6th time and thought i would resolder the motor connections 4 joints and presto it worked i then used the dash pot the adjust the speedo to a gps speedo on my phone now i can get a warrant and save alot of bucks if i could find one ill just say keep playing with it you might be lucky to fix it Cheers
    SW Vic.
    80 Post(s)
    Wreckers or Gumtree. Try Patrolapart or Readies4x4 Bendigo.
  6. #5
    Oct 2018
    Hi none in stock
