Results 1 to 10 of 10
Thread: GU suspension
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    GU suspension
    I'm looking at putting on this kit how hard is it going to be and is the price right and is it a good kit?
    http://www.ebay.com.au/itm/NISSAN-PA...item414afa493f
    Is the optional extras all I need to complete the lift? and if so how many more items would be needed and what would the total price be?
    Many thanks guys
    Whoever appeals to the law against his fellow man is either a fool or a coward.
    Whoever cannot take care of themselves without that law is both.
    For a wounded man shall say to his assailant,
    'If I live, I will kill you. If I die, You are forgiven.'
    Such is the rule of honour.
    Jun 2011
    or this http://www.ebay.com.au/itm/NISSAN-PA...item415319187b or am I getting carried away with myself? 4" should be enough to get 35" tyres under her
    Legendary
    My advice, forget the 6" lift. The police and Transport department in Logan hammer modified 4wd's pretty hard and you will attract enough attention with a 4" and 35's. With the big gaurds on the GU 35's will fit OK with a 4" lift.
    You will need the springs, shocks, panhards, brake lines, extended diff breathers, brake bias valve extender bracket, castor correction (drop boxes/drop arms/castor plates - your choice) extended rear lower control arms or adjustable upper arms, extended sway bar link pins if you still want to run sway bars (front sway bar cannot be fitted with most drop arms). Steering damper recommended depending on what is currently fitted.
    Tony
  5. The Following 2 Users Say Thank You to YNOT For This Useful Post:
    macca86 (17th July 2011), patch697 (19th July 2011)
  6. #4
    Jun 2011
    4" kit seem to have most of that stuff just needs breathers, steering damper, bias valve and extended rear lower control arms or adjustable upper arms. so looking at 3500 delivered to the door does that sound ab out right?
  7. #5
    Legendary
    $3,500 sounds about right, then you have to fit it!
    Doing a big lift properly is not a cheap exercise but if you don't do it right they are horrible to drive.
    Tony
  8. The Following User Says Thank You to YNOT For This Useful Post:
    macca86 (19th July 2011)
  9. #6
    Gert B Frobe
    Guest
    Why mess around with Ironman stuff? If you are looking to go big lifts do it properly first up and go through Snake Racing or Superior Engineering.
    On the other hand I know a guy who runs 35's on a 2" lift and he reckons its good, he only went to 3" because of the other accessories in his truck ie rear bar, drawers, two spares, loaded roof rack and towing.
    It all comes down to purpose.
  10. The Following User Says Thank You to Gert B Frobe For This Useful Post:
  11. #7
    330 Post(s)
    Yep i'd be sticking with the 4" kit mate. That add is pretty poor though as there is a long list as per Tony's post of extras you need.
    If you go with SNake Racing stuff you will give away your first born for the privileged, they set their price at around $1000 per inch of lift! you work it out!.
    I'd be advising you to go to a dealer for a package if you have the right amount of money to spend mate. Your not a suspension expert so buying bits all over the joint and making up a kit is madness. Give Shane from Suspension Stuff a call and he will hook you up with a complete kit to suit your car and accessories for that kind of money using Dobisen, Superiors and other quality parts. If your not happy then he is a phone call away and will swap stuff over to fine tune if necessary.
    https://www.suspensionstuff.com.au/s...us3mgrjj580ue2
    You also have a complete system warranty too mate, he cant say that a part bought from others is the fault.
    A professional will do all the thinking for you and it will be right. he will also only be a phone call away should you need advice when fitting.
    Oh yeah..... Go the drop boxes and not the caster bushes for a very happy drive.
    my 2c
  12. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    macca86 (19th July 2011), patch697 (19th July 2011)
  13. #8
    Advanced roon's Avatar
    Jul 2012
    pakistan peshawar kpk
    u can try iron man y61 suspension its really good for off roading
  14. #9
    Jul 2012
    ironman foam cell technoligy suspension
  15. #10
    Expert Rip'n'Shred's Avatar
    Hunter Valley, NSW
    Go suspension stuff. A lot better quality suspension components. You may be surprised with the price too, a lot cheaper than $3500.
    GU IV 2006 4.2 TDi wagon
