Results 11 to 20 of 21
Thread: 3.0 CRD Intercooler Upgrade?
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    It's all about value for money. How much do you want to spend for a very marginal increase in engine output?
  2. The Following User Says Thank You to BillsGU For This Useful Post:
    10G (16th March 2021)
    sunshinecoast
    checkout the are intercooler site (are.com.au ) . look at the patrol section . they list efficiency in percentages to give you an idea of what they can do .
  5. The Following User Says Thank You to nipagu7 For This Useful Post:
  6. #13
    462 Post(s)
    Quote Originally Posted by nipagu7 View Post
    Thats where I got my taller OEM fit scoop from. Bloody expensive though, but now you can get the same thing for far less elsewhere.
  8. #14
    May 2016
    lower west victoria
    30 Post(s)
    Totally agree Bill, that's why I've not done anything earlier.
  9. #15
    Jul 2010
    Thurgoona
    7 Post(s)
    The A.R.E stats show IC efficiency. I don't know how much increase (HP/kW) in output that equates to. Also, their stats don't show how fast you have to be going to get the desired airflow through the IC. When I require extra HP I am usually travelling slowly (either off road or towing uphill) and I don't know how much the IC - let alone the scoop - comes in to play then.
    Again - it all comes down to a personal choice and how much extra cash you have to spend.
  10. The Following User Says Thank You to BillsGU For This Useful Post:
  11. #16
    May 2016
    lower west victoria
    30 Post(s)
    I watched a video the other week with a guy from Diesel Tuning Australia. He said that a larger IC was a great idea as, as you just mentioned Bill, as you may need extra power when you're travelling slow & that is when your IC is getting the least amount of air into/through it, so a larger IC should be able to store & retain more air for a longer time, allowing it to cool more, than the standard IC.
    Sort of made sense to me.
    But then again you're looking at close to $2K for something that's hard to put a figure on how much benefit you get out of.
  12. The Following User Says Thank You to 10G For This Useful Post:
    growler2058 (16th March 2021)
  13. #17
    May 2016
    lower west victoria
    30 Post(s)
    I just searched for larger scoops for the std IC. There's tons available now. I looked maybe 2 years ago and couldn't find much at all.
    Think I'll go that way & keep the std IC.
  14. #18
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    This site is a great resource for all things IC
    https://www.are.com.au/Inter/topMountIntercoolers.htm
    I have the standard scoop on a fully welded unit. Will probably get the stealth unit in the near future.
    2008 CRD Auto Wagon
  15. The Following User Says Thank You to pollenface For This Useful Post:
    10G (17th March 2021)
  16. #19
    May 2016
    lower west victoria
    30 Post(s)
    Threw some $$$ down on one of these ...
  17. #20
    462 Post(s)
    just looked at how much the ARE Cooling scoops are. Holy Chit! I know it was dear but I don't remember paying that much for mine back in the day...
    Edit : found an old pic with the ARE scoop... Looks different now though...
  18. The Following User Says Thank You to mudski For This Useful Post:
    10G (18th March 2021)
