Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 3.0 CRD Intercooler Upgrade?
    May 2016
    lower west victoria
    30 Post(s)
    I have a stock 3litre CRD 2014 Y61.
    I've got a dawse & needle valve mod, EGR block and so on.
    A few years ago up in Alice Springs, mid 30's and the GU was real sluggish, I put it down to the hot air as everything improved once the weather cooled down. So I'm guessing I was running out of cool air?????
    A few years ago I fitted a fan under the IC, but haven't really driven it in hot weather since fitting it, so haven't been able to test it's effectiveness.
    I'm wondering, how much benefit is noticeable from fitting a larger intercooler, is it worth the extra money????
    462 Post(s)
    On a stock engine, not worth it in my opinion. Even on my old Di which had 25 psi running through it I had an aftermarket, stock sized, intercooler and the thing went great. More cooler air will be beneficial, don't get me wrong, but how much, would be the question....
    10G (16th March 2021)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Mudski is right. I wouldn't bother unless the current intercooler is leaking. Then I would get the current IC modified with a more efficient core welded to the existing ends. Works well and will fit perfectly. Some aftermarket ICs are not a perfect fit - like the one I bought years ago.
  6. The Following User Says Thank You to BillsGU For This Useful Post:
  7. #4
    May 2016
    lower west victoria
    30 Post(s)
    So to ask a dumb question, if I remove the IC, block one end and submerge it in a bucket of water, & blow air into it, that should tell me if it's leaking, correct??
  8. #5
    175 Post(s)
    You'd know if it were leaking . There will be gunked up oil stains on it..it's very evident.
  9. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    10G (16th March 2021), mudski (12th March 2021)
  10. #6
    Jul 2010
    Thurgoona
    7 Post(s)
    If you do that you are likely to rupture it with too much air pressure - unless you use a regulator. Easiest way is to block both ends and put it in a tub of water and see if any bubbles emerge.
    But as mentioned above - you should see oil stains on the IC where it is leaking.
  11. The Following 2 Users Say Thank You to BillsGU For This Useful Post:
  12. #7
    462 Post(s)
    Yep. A crimped end tank intercooler will pretty much be guaranteed a leaking intercooler.
  14. #8
    462 Post(s)
    I remember doing the original IC on my ZD by blocking both ends, submerging it in water and using a bike pump with the needle end on it for footballs and slowly pumping air into to that way.
  15. The Following User Says Thank You to mudski For This Useful Post:
  16. #9
    May 2016
    lower west victoria
    30 Post(s)
    Thanks everyone for the help.
    What about the larger bonnet scoops? What do people think of the usefulness of them?
    I'm of two minds. 1, they should scoop more air in, but are they more effective? 2, will the extra scooped in air, be forced through the IC with less force than a std scoop, so therefore create less cooling of/for the IC?
  17. #10
    462 Post(s)
    Larger scoop is far better than the useless stock scoop. More air cooling will mean more cooling capacity. On the other forum a while ago there was a guy who did and air flow test using a like a paper string set up and watching air flow hitting the bullbar then pretty much going over most of the OEM scoop. Showing the usefullness of a taller scoop.
  18. The Following 2 Users Say Thank You to mudski For This Useful Post:
    10G (16th March 2021), growler2058 (16th March 2021)
