9th March 2021, 06:42 PM
In need of help!!
Hey guys have rebuilt my GQ (tb42 EFI) from the ground up and I have put the battery in and nothing happened .power to the starter motor(checked with multimeter) but no power to anything else turned the key and not a single thing happens all fuses have been changed so can’t be a fuse.any help would be very appreciated.
Cheers.
9th March 2021 06:42 PM
9th March 2021, 07:50 PM
Start with the fusible links near the battery. They are wire that is designed to heat up and blow if there is a short circuit. Silly question, did you fit the battery the right way, +ve to +ve and -ve to earth.
9th March 2021, 08:47 PM
mudnut
Ok will have a look tomorrow,yes battery hooked up correctly and earthed from chassis to body and body to engine
9th March 2021, 08:52 PM
Moderator
Yes work away from your battery positive. You should find the problem soon enough.
Check out my Toy -->
Rogue Dung Beetle
9th March 2021, 08:55 PM
did you charge the battery before you tried to start the car . how long was the battery sitting without being charged . if it had gone flat for a while it might be stuffed , it might test at 12v or higher but have low amp output when cranking . if you haven't already , try another battery that is known to be good.
The Following User Says Thank You to nipagu7 For This Useful Post:
threedogs (10th March 2021)
10th March 2021, 12:40 AM
Yeah brand new battery and has been tested on a td
10th March 2021, 01:09 PM
Hi what a dilemma, do one thing at a time
when checking, have you any spare cables
that you may have missed, starter, alternator??
it sounds like youve missed something
10th March 2021, 05:23 PM
I have checked and the fusible link wasn’t connected but when I connected it up it started to smoke
10th March 2021, 05:25 PM
Is there power getting to the start solenoid on the starter motor (I am assuming not an air starter motor).
If so try gentle adjustment on the side of the starter casing with this precision device RISTBP32_002.jpg
2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
10th March 2021, 05:27 PM
PatrolOwner69
You dropped that in when I was posting.
OK that means your drawing too much current for the circuit, so likely you got a short or a ground out somewhere on that circuit...or the fuse was not rated for the circuit. What size fuse link did you use.
Have a read here https://www.patrol4x4.com/threads/gq...horted.100539/
as that may help, evidently the 65 Amp was upgraded to a 75 Amp at some stage. The GQ blokes can offer more accurate info.
