Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: How to Fix Scratched Mirror Frame Properly?
    Yes wet rub means Wet and Dry paper used wet.
    You will have to work to hard edges. This may mean painting the whole mirror on that side which is not really that big a deal and probably what should be done.
    Alternatively, paint to the edge corners only. Mask there.
    Once painted you could rub the blend line and buff.
    Be gentle on any edge though as it is sharper and easy to rub through. Clear would b ot really help avoid this.
    Assuming your car is Not Black and only the mirror is black just paint the whole thing, it will never be compared to the other side. No blending needed then. We are now assuming you have a rattle can you are using to paint the whole thing.
    Just looking at your pics again. Have you tried taking that surround off? Painting off thr car would be much easier
  4. #13
    Dec 2021
    I just want to complete it, my friend, to remove scratches on my car body, there is a recommendation for a similar cleaning here https://gnewscar.com/remove-scratche...aint-low-cost/
  5. #14
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    if you fold the masking tape edge over it helps reduce the hard line u get when painting.
