Results 1 to 8 of 8
Thread: Door trim removal
    Patrol God Stropp's Avatar
    23 Post(s)
    Door trim removal
    Can anyone tell me if this door trim pops off as I need to remove mine to get it recovered.[ATTACH=CONFIG]
    2003 gu3 td42tdi roaming this great country
    May 2016
    8 Post(s)
    yes it pops off take off handles and arm rest . carefully pry it off . Take a look at Australian door cards I just used there ABS plastic ones .
    nice job and no more cardboard crap !
  4. The Following User Says Thank You to Tip12345 For This Useful Post:
    Stropp (25th February 2021)
    Expert Truckus's Avatar
    Feb 2021
    Central Coast NSW
    I have read that it pops off, can not tell from mine, trim is different (But the manual does not seem to indicate this) however I would do this with the entire trim removed to avoid damage or issues when putting it back in later. I think this is what Tip is talking about too,the entire trim.
    Here an easy trim removal vid (its for mirror changes) but old mate walks you through the trim removal.
    If you got a plastic spectacular or trim removal tool that is better than using the screwdriver to pop the trim clips away, as less likely to do damage to coatings and plastic trim, so if you douse a screwdriver, be gentle or wrap it in thin rubber strip or elec tape for the pry work.
    Also here is a link to the trim section of the manual for the GU https://nissan.club/applications/cor...t.php?id=38441
    2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4Ē XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
  6. The Following 2 Users Say Thank You to Truckus For This Useful Post:
    MudRunnerTD (23rd February 2021), Stropp (25th February 2021)
  7. #4
    309 Post(s)
    Strop see the vid above mate. the whole door card lifts out of the window gutter once it is popped off the door.
  8. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  9. #5
    421 Post(s)
    That little pad thingo is connected to the door card on the inside. so the entire trim needs t be removed.
  10. The Following User Says Thank You to mudski For This Useful Post:
  11. #6
    23 Post(s)
    Bugger I was hoping to just pop that bit off, oh well itís got to be done as itís got a rather large split.
  12. #7
    421 Post(s)
    5 minutes mate and the door trim is off. Easy!!!
    Stropp (26th February 2021)
  14. #8
    23 Post(s)
    Thx guys will do it when I get to Geelong
