Results 1 to 10 of 10
Thread: TD42 drain coolant from Block
    May 2016
    8 Post(s)
    Hi all is there a drain on the block to get the coolant out ? have the head off and the water pump out but cant find where I might drain the rest of the coolant .
    I want to change to a different type of coolant . thanks to all .
    Feb 2012
    Passenger side/rear of the block
    It can be difficult to access in the car.
    If it's a factory turbo, cracking the turbo coolant line banjo bolt and allowing it to drain is much easier.
  4. The Following 3 Users Say Thank You to geoffayres For This Useful Post:
    mojo53 (27th November 2021), mudnut (18th February 2021), mudski (18th February 2021)
    May 2016
    8 Post(s)
    thanks mine is a factory Turbo I am not sure its a Water cooled one . I did not look or noticed when I pulled it down to replace thw head fuel pump Injectors etc . thanks for the heads up
    Feb 2012
    Some have reported they can access the drain plug with a few socket extensions from inside the wheel arch.
    Doesn't work for me though. The exhaust partially blocks it.
    465 Post(s)
    Quote Originally Posted by geoffayres View Post
    Long time no speak mate. Good to see you still trawl the forums.
    Cracking the turbo coolant line is what did as well and seemed to work well and is fairly simple to access.
    Feb 2012
    Long time no speak mate. Good to see you still trawl the forums.....
    Yes, it has been a while hasn't it?
    I'm still snooping around. Don't post much though...
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    That's a pic of part of my engine on the engine stand back in 2015 when I was getting it ready for conversion. The turbo oil return is sideways because the turbo is mounted 100mm further forward on a steampipe manifold.
    Good to see the pics are still useful
    John
  10. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    geoffayres (19th February 2021), mudski (19th February 2021)
  11. #8
    Feb 2012
    I wondered if you'd spot it....
    There was another pic that was handy, but I went with yours 'cos it showed the turbo coolant line.
  12. The Following User Says Thank You to geoffayres For This Useful Post:
    jff45 (19th February 2021)
  13. #9
    465 Post(s)
    Your input is always useful mate.
  14. The Following 2 Users Say Thank You to mudski For This Useful Post:
    geoffayres (19th February 2021), jff45 (20th February 2021)
  15. #10
    May 2016
    8 Post(s)
    Thanks to all got the coolant out .
    I will be glad to get it back together . next job put the new fuel pump on .
    Its a big job to change the head, fuel pump, water pump , Radiator, etc etc
