Results 1 to 6 of 6
Thread: TD42 22mm injector socket
    May 2016
    8 Post(s)
    Hi all where can I buy the 22mm injector socket for the no1 injector .
    Anywhere. Just go to a tool shop and get a deep 6 point socket. And just cut a slot in it with the grinder.
    Sometimes you can get lucky and the screw that holds the wire onto the injector can be undone and a standard deep socket can go on then.
  4. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    MB (17th February 2021), MudRunnerTD (17th February 2021), Tip12345 (17th February 2021)
    @Tip12345
    You could also purchase a 22mm oxygen sensor socket as well. Which most decent tool shops should carry.
  6. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
  7. #4
    460 Post(s)
    Eh? I just bought a standard 22mm Deep socket. No grinding required. Did all my squirters, twice. Whats this screw and wire you speak of?
  8. #5
    On the TD42Ti there is a small sensor on the number one injector that senses the injector pulse. Its used in conjunction with some basic timing control of the pump and the emissions crap they put on them.
  9. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (17th February 2021)
  10. #6
    460 Post(s)
    Ah of course there is. Thanks.
