Results 1 to 7 of 7
Thread: Auto Hub Torque?
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Auto Hub Torque?
    Wondering if anyone can help me out with the torque settings for the 6 big bolts that hold the auto hubs on??
    2013 Y61 3L Manual
    Thanks.
    469 Post(s)
    From my very poor memory it’s circa 40Nm 10g Mate @AB can hopefully grab his workshop bible binder for you to double check, I should’ve kept it last time I borrowed it
  4. The Following User Says Thank You to MB For This Useful Post:
    10G (15th February 2021)
  5. #3
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    40ftlb or 56nm according to the manual.
  6. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    10G (15th February 2021), MB (14th February 2021)
  7. #4
    469 Post(s)
    Good Work Graigstar Mate
    10g Mate, I can highly recommend purchasing/carrying a hardened Allen/Hex key thingy for your project underway and or any unfortunate CV replacements that hopefully never arise out there
    Standard mild steel Allen/Hex keys do as much damage to themselves as your poor old faithful studs Brother!
  9. #5
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Thanks guys, I appreciate the help.
    I had a 1/2" to 3/8" adaptor coz I have a 3/8 allen key thingy like that MB. The adaptor split in two HAHAHA.
    How tight should I do up the bearings?? They were a tad loose, I just tightened them up by hand using the 2 pronged socket, didn't use a ratchet/handle.
  10. The Following User Says Thank You to 10G For This Useful Post:
    MB (15th February 2021)
  11. #6
    SW Vic.
    80 Post(s)
    The book says to really tighten the bearing to 145ftlbs - 167nm. Rotate the hub a few times in both directions. Loosen the nut to zero, then tighten to sweet bugger all, (3-5nm.) Turn the wheel again and do another 3-5nm. There is more to it but in the manual Pages FA4-6
  12. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    10G (15th February 2021), MB (15th February 2021)
  13. #7
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Yeah, that is bugger all.
    Out of the 4 small screws in the locking ring, 3 were stuffed, had to butcher some small screwdriver bits to get 'em out. Surprisingly I found 4 screws of the same thread, bloody miracle.
  14. The Following 2 Users Say Thank You to 10G For This Useful Post:
    MB (15th February 2021), mudnut (15th February 2021)
