Results 1 to 4 of 4
Thread: Tb42 GQ charging issue
    Oct 2020
    Hi again all!
    My tb42 gq is putting out 15.5v at idle measured on the alternator post
    Battery measures 15v at idle.. battery measured 10.8v switched off and somehow just starts the car
    Is it likely my alternator AND battery are had it?.. this was very out of nowhere, just noticed it struggled to start this morning.
    Is there a possibility it’s a problem with the sense wire? I’m not very cluey when it comes to auto elec. there’s no battery light on the dash
    Cheers!
    80 Post(s)
    That sounds as if the battery has dropped a cell. Try borrowing another battery and test it again. Check all the connections and connectors.
    Oct 2020
    Would that cause overcharging? Or should the alternator be regulated to 14.4 regardless
    80 Post(s)
    It could be that the alternator has overcharged the battery, but keep it simple. If you can, try another battery and then you will see if it is the alternator causing problems.
