Page 3 of 3 FirstFirst 123
Results 21 to 21 of 21
Thread: Diesel Pre Filter plus Factory Filter
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Yes I have a bypass setup on mine with a one way valve in it so if the pump stops fuel can still be drawn through the bypass.
    I've done the same with the Carter 4600. When I mounted the pre-filter, I pulled the pump fuse as a test and it drove correctly albeit with new filters and a freshly rebuilt pump and without making excessive demands on fuel. I just wanted to know I could keep going if the pump failed.
    There are pumps that will allow fuel through them if they stop working.
    John
  2. The Following User Says Thank You to jff45 For This Useful Post:
    MB (14th February 2021)
