Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: When to drain oil??
    465 Post(s)
    Quote Originally Posted by Caboosewa View Post
    You might not want let it drain to long, could empty The oil pump and create extra wear on start up, the filter is what gets rid of any thing that’s not oil and the oil will always be black that’s just old school Diesel engines
    On a TD42, the oil pump is above sump level. The one or two seconds the pump has no oil in it wouldn't be of any worry. There will always be some residual oil on the gears anyway....
    Feb 2011
    Shed
    45 Post(s)
    Drain when hot 'cos I just love the extra challenge of getting into the difficult to reach filters when they are hot, & nothing better than getting hot oil splashed on me when cracking open the sump plug!
    Nope
    But I do drain it hot for all the reasons others have given.
    Exactly! I remember changing the td42 in my old GQ. Dropped the plug when raging hot oil spilt on my hand and landed in the funnel, blocking it. Then while said raging hot oil was spilling all over my lawn, I shoved my hand back in the raging hot oil to get the pharkn plug out. Took a few years for the lawn to recover from that little mishap
  4. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    Cuppa (9th February 2021), Rossco (9th February 2021)
  5. #13
    May 2016
    lower west victoria
    30 Post(s)
    You might not want let it drain to long, could empty The oil pump and create extra wear on start up, .....
    But wouldn't that happen whenever you let the vehicle sit, like overnight for example?
  6. #14
    109 Post(s)
    Haha I remember your original post on this incident! What a "Sorry Darl" you had to give!
  7. The Following User Says Thank You to Plasnart For This Useful Post:
    growler2058 (9th February 2021)
  8. #15
    Feb 2021
    It’s a different ball park but you have a 10 min window to change the oil in a Ford ranger or you risk drying out the pump and it has to be manually primed, expensive job to fix. I just don’t think letting the oil drain over night is a smart thing to do
  9. #16
    465 Post(s)
    Patrols and Ranger are two totally different vehicles. Real and, well, they have their place in society somewhere. You won't be drying a pump out on a Patrol.
  10. #17
    Feb 2021
    I did say that there different mate and if ppl wanna drain there oil for 24 hours go for it just don’t see the point
  11. #18
    465 Post(s)
    I don't see the point as well. I leave it for 10 or so minutes after shut down, Let it drain for another 20 or so then refill. Each to their own.
  12. #19
    Feb 2011
    Shed
    45 Post(s)
    I get flashbacks every oil change still
  13. The Following User Says Thank You to growler2058 For This Useful Post:
    Plasnart (9th February 2021)
