15th July 2011, 02:27 PM
ignition and flat battery trouble
hi guys i have a question for ya's
Recently i have encountered some trouble on my patrol (93 GQ wagon) if i turn the key to run but not start the car for example to wind up electric windows then turn the car off without starting the ignition stays on and volt meter reads like 12 volts its not until you start the car then turn it off it goes away ? ANY IDEAS
Also not sure if prob is related but the dam main battery keeps going flat over nite if you drive around it will charge it up and is fine all day and even if you do a lot of driving it can last a whole nite without goin flat damn thing the 2nd battery never goes flat either oh and its a new battery like 3 weeks ago
15th July 2011 02:27 PM
any ideas help would be greatly appreciated guys
15th July 2011, 02:30 PM
304troll
Without looking you may have a stinging main relay somewhere?
15th July 2011, 02:32 PM
Banned
And how old is the battery? Sounds like it charges up as such from the alternator when running, but isn't holding charge ...
Patch and crew know more about this stuff anyway mate, so feed them the info and no doubt they'll help you sort it!!
15th July 2011, 02:50 PM
The first thing that comes to mind is a faulty ignition switch, does it feel notchy or loose?
If its a diesel does it have a shut down timer fitted?.
Your battery draining overnight could be related, you could try disconnecting one terminal off the battery overnight then reconnecting it in the morning and see if it starts.
15th July 2011, 02:51 PM
have you got any auxiliary components running directly of the battery going flat?
15th July 2011, 05:16 PM
cheers guys
um its a 304 holden fuel injected v8 running on it is everything except the uhf radio and the battery is only like 3 weeks old i like the sound of a sticky relay i will have a bit of a squizz at them tomorrow and i disconected the barrel and switch and it still does it when ya switch it to b+ and unplug the switch
may be a job for a auto elec to look at
15th July 2011, 05:22 PM
#8
Ignition staying on sounds like either sticking ignition switch or main relay.
Battery going flat could be a number of things. Have you checked the charge rate of the alternator?
A common fault with Patrol alternators is a faulty diode which will drain the battery while the engine is off. Other than that it's time to use an amp meter to find out how much current is being drawn out of the battery then start pulling fuses out until the reading drops. That will tell you which circuit is causing the problem and you can narrow it down from there.
Tony
15th July 2011, 05:41 PM
#9
That changes things a bit.
Try disconnecting the 2 pin plug from the alternator, see if that fixes your ignition problem.
18th July 2011, 03:16 AM
#10
hey yendor i tried that and yeah bang on bevan done well cheers mate
