Results 1 to 2 of 2
Thread: TB45 Coolant Ratio
    Jan 2021
    Newcastle NSW
    TB45 Coolant Ratio
    Hi There
    I don't have a service manual yet and was wondering if anyone could advise of the factory recommendation for coolant to water ratio for the TB45E Engine. Thanks
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by Peteb View Post
    Hi There
    Pretty sure the information is on the coolant bottle or just buy ready mix . remember don't mix coolants and pays to start fresh e.g. empty and flush out your system using water.
  4. The Following User Says Thank You to altech For This Useful Post:
    MB (22nd January 2021)
