29th December 2020, 04:53 PM
Snapped Fitting off radiator top tank TD42Ti
Damn I am getting so clumsy doing my own servicing. Snapped the top fitting off the radiator top tank with the 10l container of new oil as I was pouring it in.
Is this a simple fix as tapping in a brass fitting and re attaching the header tank hose or do I need to go a whole new top tank?
The Following User Says Thank You to Pimpmyhubcap For This Useful Post:
29th December 2020 04:53 PM
31st December 2020, 10:11 AM
Quite common believe it or not, not sure how you would go with tapping it as it is under pressure, me I’d go a new top tank and put a shroud over it so it doesn’t happen again
The Following User Says Thank You to Stropp For This Useful Post:
2nd January 2021, 01:36 AM
The Following User Says Thank You to MB For This Useful Post:
Stropp (2nd January 2021)
2nd January 2021, 01:10 PM
I did the same a few year back and just ran a tap through it and screwed a barb fitting in with the aid of a little liquid thread tape. Never leaked once. Was actually stronger than how it was...
The Following 2 Users Say Thank You to mudski For This Useful Post:
MB (3rd January 2021), Stropp (2nd January 2021)
3rd January 2021, 07:03 AM
I stand corrected Mr Mark Mate, Well Done!
Sounds like it could be a handy fitting to keep onboard if it ever was to easily happen to us all out there.
Was it simply something like this you used to keep rolling Mate?
mudski (3rd January 2021)
3rd January 2021, 11:52 AM
MB
Exactly mate. Just can't remember the size I used. I think it was a 1/8 NPT thread with a 1/4" barb from memory. I drilled out the hole first to suit the thread I was going to tap first, just like you would when tapping a metal thread...
MB (3rd January 2021), Stropp (6th January 2021)
6th January 2021, 04:55 AM
Maybe it is possible to solder the old fitting? Now there are plastic electrodes for various plastics. Radiator tank made of PP plastic.
Nissan safari Y60 TD42T +4", wheels 37"
Russia.
6th January 2021, 05:13 AM
#8
Although I just changed the tank.
Russia.
The Following 2 Users Say Thank You to Seluntiy For This Useful Post:
MB (9th January 2021), Stropp (6th January 2021)
9th January 2021, 03:08 PM
#9
SCA had a fitting on the shelf which had the right size barb for the hose and a big enough thread diameter to go into the hole. Used a 12.5mm drill to clean out the hole and then used silicone grease and the actual fitting (back and forth) to tap it out. plastic there is around 2mm thick so made sure I got 3/4 of the thread inside. Bit of thread tape and it's done.
The Following 4 Users Say Thank You to Pimpmyhubcap For This Useful Post:
MB (9th January 2021), mudnut (9th January 2021), PeeBee (9th January 2021), Stropp (11th January 2021)
