12th February 2021, 01:53 PM
Diesel Pre Filter plus Factory Filter
2006 TD42 DX Patrol Ute
G'day everyone,
I'm new to 4x4, have only had my rig for a couple of years and as far as I know it's still stock.
I'm lined up to have a pre-filter (professionally) installed.
The local shop uses the Flash Lube brand with the clear bowl which I think will do.
I'm wondering though ... is it a simple matter of them hooking it up, plumbing it in and all will be well?
I've been reading about lift pumps being necessary & as embarrassing as it is to say it ... I wouldn't know if I have one yet from factory or not.
Just thought I'd start by seeing what experienced people thought here / ask silly questions here before asking them elsewhere.
Cheers folks.
The Following User Says Thank You to Risky For This Useful Post:
12th February 2021 01:53 PM
12th February 2021, 02:03 PM
Moderator
Hi mate, yes i would consider adding a Lift pump toyour setup. You do not have one from factory. The Fuel pump creates vacuum and sucks out from the back tank to the back of the pump, adding a further restriction just ades to the Starvation. adding some positive pressure to the back of the pump will be rewarding.
Check out my Toy -->
Rogue Dung Beetle
The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
MB (12th February 2021), mudski (12th February 2021), Risky (12th February 2021)
12th February 2021, 07:48 PM
Risky (15th February 2021)
12th February 2021, 09:25 PM
Just make sure you have spare filters on board. I know those filters your mechanic will use, and they are not something thats easily available if you are out in the middle of shit creek with a blocked filter. Also another concern is the flow rate. while it will be good with a stock TD42, having two fuel filters inline will create flow issues with a modified TD, even a modified ZD.
MB (12th February 2021), Risky (15th February 2021)
12th February 2021, 09:47 PM
Breadmaker Shaker
Not having a go, and might learn something here myself, but why would you need a pre filter in a TD42?
12th February 2021, 09:52 PM
Plasnart
The only reason I think, is if you live in a remote area where fuel supply is less than desirable.
MudRunnerTD (12th February 2021)
12th February 2021, 10:12 PM
Moderator
^^^^^^^ what he said ^^^^^^^^
Really they are beneficial to catch water in fuel and other contamination found in crap tanks. Even the onboard tank.
Rogue Dung Beetle
12th February 2021, 10:25 PM
Breadmaker Shaker
mudski
MudRunnerTD
Umm yeah, but the standard fuel filter has a water bowl and drain valve at the bottom, so why do you need another to complicate things?
12th February 2021, 10:27 PM
Plasnart
To answer your question, you don't.
12th February 2021, 10:30 PM
Breadmaker Shaker
mudski
That's why I asked the question.
