Results 1 to 9 of 9
Thread: Rd2.8 won’t fire with key
    Dec 2020
    Caloundra
    Hi guys I need some help please, I’m only new to this site but I have gotten so much from reading your forums, so a little while ago I had dramas hot starting so I replaced the advanced plate on the injection pump, Nissan replace it for me, they also told me it had a Nat code that went when they replaced the plate, now a few weeks later and it won’t fire with the key but will if I roll start it and drives normal, Nissan has told me I need to replace the pump now, I’m not to sure as I rebuilt the motor pump and injectors 50k ago, can someone please help me on what they think I should do it will be greatly appreciated
    The master farter
    mudski's Avatar
    462 Post(s)
    Sound electrical to me. do the 2.8's run a fuel shutoff solenoid on the pump?
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Does the starter sound slow? It could be poling (rubbing on the field piece )
    Dec 2020
    Caloundra
    It has a fuel cut solenoid, I’m not to sure where it is maybe on the pump, what would it look like, I just picked it up from Nissan roll started it, run normal and I drove it 30km home and it didn’t miss abeat
  6. #5
    Dec 2020
    Caloundra
    It doesn’t at all sounds normal, they started it with start ya barstard earlier today and it took bit but fired
  7. #6
    The master farter
    mudski's Avatar
    462 Post(s)
    Type this into google, I'm sure you'll find something.
    rd28 fuel cut solenoid
  8. #7
    472 Post(s)
    G’day Errol Mate!
    I don’t know anything about the old faithful heard RD2.8 diesel and even less about electrical stuff. Are you 100% sure there’s no air sneaking into your diesel fuel line system on such and old beauty?
  9. #8
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Weird that it roll starts and runs fine. That should cross out the fuel solenoid shouldn’t it?
  10. #9
    472 Post(s)
    Wacky theory, maybe try getting your Mrs to turn the key cranking whilst you hold a diesel soaked rag around the shed air compressor line you’ve just shoved down its filler pipe?
    Pressurise that old system up with your 3rd/4th & 5th pinkies blocking tank breatherers
