Results 1 to 10 of 11
Thread: Info on a patrol
    Dec 2020
    Question Info on a patrol
    Hey, im new to this forum and was interested in buying a nissan patrol soon, but am not to sure what models i should steer clear from and be looking for, i have found one and was hoping to get some feedback on it? Cheers for any help
    174 Post(s)
    Welcome to the forum Nathan. A bit of info on what you've found might get a bit more feedback. Depends what use you have in mind for one as to what is the best buy. I have only owned a TD42i engined model & consider it was a great choice - best car I've ever owned, reliable & trustworthy, & excellent off road - just what I wanted for remote area touring. Later model 3.0 litre jobbies are cheaper to buy & plenty get a pretty reasonable mileage out of them, but as you are probably aware some of the earlier 3.0's did gain a reputation for going bang & now & then someone posts with a tale of woe, but far less often than the reputation would lead you to expect. Hopefully you'll get a few others here who will be able to tell you about a couple of simple things you can do to prevent this happening, & which particular models created the reputation.
  4. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    growler2058 (2nd December 2020), MB (3rd December 2020), Rossco (2nd December 2020)
    Sep 2018
    queensland
    id say get a 3.0L crd about 2008 or newer, the older 3.0L Di were know for issues.
    alot of people like the 4.2L simple and reliable but abit slower from what im told
    what have you found?
    Dec 2020
    ahahha sorry i forgot to add the info somehow, but heres some info about it
    2011 Nissan Patrol GU 6 MY10 DX
    Coil Cab
    121,933km
    Priced at $30,000
    Sep 2018
    queensland
    sounds fair,
    things to note on the 3.0L crd engine
    the exhaust manifold is common to warp and snap studs. it will cause a squeal under acceleration. fix is replacing the manifold and all the studs.
    also the egr pipe around the back of the head can crack and cause the squeal to.
    some people mistake if for belt squeal. and the belt tensioners do also fail.
    put a oil catch can on it and a 2nd fuel filter for finer filtration.
    thats my 2 cents
    i own a 2008 3.0L crd wagon 205,000km and have it for 4 years and 45,000km
    Dec 2020
    Sweet man thanks, is there anything else i should be watching out for?
    Welcome to the forum. Check the rear spring mounts for cracking and stretching. It is a known fault and there are kits available to prevent and rectify it.
  10. #8
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate
  11. #9
    Dec 2020
    Have seen a 2005 TD42/coil for $34,995 with 161,203km, guessing these are more popular due to the price increase ahahah
  12. #10
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Nathan_ View Post
    Buy it!!!!!!!
