Results 1 to 10 of 18
Thread: Me mates lookn at a TD
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Hey, so a friend of mine sent me a link to a gu TD42 he is considering buying and asked my opinion. I told him Id take the question straight to the brains trust!
    We're OK with the basics of used car buying but having an aftermarket intercooler and squeezing 25 pound I'm after some advice on the mods done and if there are any short cuts or bad set ups to look out for.
    Here's the ad:
    https://www.gumtree.com.au/s-ad/laun...rol/1262169579
    Cheers mad dogs!
    Hello from Under Down Under!
    201 Post(s)
    It looks like a pretty good buy. The cheap Chinese turbo without a real tune is the only concern but if it were me I'd probably leave the turbo and just get it tuned properly.
    taslucas (25th November 2020)
    Aug 2011
    North West Tas
    56 Post(s)
    Are there any weak spots to look for in a cheap turbo or are they basically the same as an expensive one but just prone to wear a bit quicker?
    201 Post(s)
    To be honest I don't really know. There a thousands of guys out there running them and they are probably not that bad.
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I don't think the Kinugawa/Mamba turbos are really in the "cheap chinese" category. They're made in Taiwan and have earned a reasonable reputation for themselves.
    I call the "cheap chinese" the ones on ebay for $300 odd..
    John
    461 Post(s)
    Its missing the radiator shroud and foam. Must of had the radiator out a few times and got lazy by not putting it back in, making quick removal of the radiator. Done this a gazzilion times myself. Looks like a good truck though. Got a lot of fruit on it.
    If you go look at it, have a look at the radiator support panel, where the front body mounts bolt in. They are notorious for rusting out there, check out my build thread for where it is. From post #289 onwards
    http://www.nissanpatrol.com.au/forum...d-Thread/page8
    Rear coil towers too. Look to see if they are torn or not. Hopefully not..
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Rossco (26th November 2020), taslucas (26th November 2020)
  10. #7
    Aug 2011
    North West Tas
    56 Post(s)
    What did you mean "without a real tune"? Just ask the seller if it's had a professional tune?
  11. #8
    461 Post(s)
    He's trying to say a real tune is paying for a tune on a dyno, where its done properly, measuring air/ fuel ratio's etc etc. Some just do a "screw driver" tune themselves, where they might see more power, but its not a proper tune.
  12. #9
    Aug 2011
    North West Tas
    56 Post(s)
    The ad says tuned to 25 psi so I guess we just have to ask where or how it was tuned up. Not many good dyno tuners here so that's of concern
  13. #10
    201 Post(s)
    There are thousands of TDs out there running backyard tunes. I am sure some of them do a good job but some of them would have no idea.
    I wouldn't consider it a big turn off for the car but I would factor in a few hundred dollars to get it tuned on a dyno by a professional.
