Results 1 to 10 of 12
Thread: Tyre repair kits
    Jul 2018
    Tyre repair kits
    What are people using for their tyre repair kits these days? Thoughts and experiences most welcome
    107 Post(s)
    I have one of those DIY kits.
    Only had one flat and that was
    last year. I picked up a small screwdriver bit in the tread area.
    After some reaming I inserted that wick with the adhesive.
    pumped it up and worked a treat.
    now I have new BFG ats and im not expecting ang flats soon lol
    Jul 2018
    brand .. ?
    I've looked at all sorts on fleabay and amazon .. trying to head towards the black rubber type wick with vulcanizing rubber cement
    156 Post(s)
    I have not used the dog turd style kits in the past, although I carry a set, believe they are quick and effective.. If i have punctured a tyre its typically beyond the repair limits of these rope, so I use a glue on patch inside the carcase of the tyre to seal the metal bands from coming thru and then whack a tube in it. for tube repairs i like the heat vulcaniser type with the clamp and burning pad, however have had the same success with the glue on patches.
    Manufacturer of the Complete Camp Oven System
    Website:http://davesstuff.net/
    Vendor Page: http://www.nissanpatrol.com.au/forum...ar-That-Works/
    Tuturial Video's: http://www.nissanpatrol.com.au/forum...ted-on-Youtube
    Jul 2018
    im only looking at emergency repairs .. wont be pulling tyres off rims or anything .. but I'm looking for a set that wont fail like so many have had with all different brands from fleabay and ARB
    109 Post(s)
    I have a ridge ryder tyre repair kit,have used it more than once,great kit all the handles are made from steal and feels solid
    I just bought my lovely wife Jess a new model Patrol, as she deserves it more than me
    Jul 2018
    I think I saw that advertised .. I will scope it out .. thanks for the heads up :-)
    Sep 2011
    adelaide
    9 Post(s)
    G`day Timbo
    I do a lot of station driving where punctures are common, and have had the odd flat.
    I carry two types of repair kits , the ones your looking at.
    One is from ARB and is a product that can break and cause you a little injury. The problem is the plastic "T" handle will break and youll end up with the steel pin through your hand. with a flat it takes quite a bit of pressure to ream out the puncture and put a plug in. As you will see I`ve welded a steel T handle on one o the offending tools. The other set is Sealastic brand ,made in Germany. I`ve had this kit for around 30 years and boy it`s been a top tool. The cord plugs are what ever is avalible and so is the rubber sealant, if I`m out of sealant i just bung the plug in and never had a problem. Yes you can put two or three plugs in a silgle hoe and with luck it will get you out of trouble. I also carry a range of patches which are self adhesive and a roughing up file and patch roller. These also will and have gotten me out of trouble. To get the tyre off the rim I can recommend Tyre Plyers a great product and easy to use. A couple of tyre leavers wont go astray, if you carry a large, I mean a flat blade screwdriver of over 18 inches long , one tyre leaver is enough.
    Hope this helps
    Having trouble up loading photos
  10. #9
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    9 Post(s)
    Same here, bit bulky to store, but works great, try and store it flat as the lube will run left in a hot car for 12 months (as i found out), or tape around the lube container lid.
  11. #10
    Sep 2011
    adelaide
    9 Post(s)
    Trre repair tools
