Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: ARB Compressor Wiring
    300 Post(s)
    the bus bar just lays out the relay dazz
    Cheers mate, yeah that is what i figured too but without pin codes its a little misleading when he adds colour to the wire codes.
    All good. Hopefully my last post sorts it out.
    Advanced Mcflurry's Avatar
    Dec 2018
    Yeah just a layout for the relay mate. Really appreciate the info, I think I understand it (few beers in for covid relief) will draw it out again with that info and see what ya reckon!
    2009 GU
  4. The Following User Says Thank You to Mcflurry For This Useful Post:
    MudRunnerTD (26th October 2020)
  5. #13
    161 Post(s)
    On the relay there will be a number next to each pin. If you draw the relay following the convention in the following link showing which wire goes to which pin it will probably help the confusion.
    https://www.12voltplanet.co.uk/relay-guide.html
    2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, Tyredog TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare)
  6. The Following User Says Thank You to Cuppa For This Useful Post:
    MB (27th October 2020)
