Results 1 to 10 of 15
Thread: Prop shafts nuts and bolts 2012 Patrol Y61
    Sep 2015
    In re. to my post about the slip joint locations, it is now time to reinstall the shafts. I am looking at replacing the existing nuts and bolts. Can anyone recommend where to get them? Nissan is of course the obvious choice, but usually the most expensive. Boltmasters were no help whatsoever.
    461 Post(s)
    The nuts are flanged, but any nut and bolt shop will have them, theres nothing special about the thread. How come Boltmasters were no help? Did you take a sample in to them?
    May 2016
    8 Post(s)
    the bolts are stepped a/ think they are a special .
    If you get stuck I will go out and take one out and have a measure .
  5. The Following User Says Thank You to Tip12345 For This Useful Post:
    MudRunnerTD (15th October 2020)
    461 Post(s)
    Quote Originally Posted by Tip12345 View Post
    Mine aren't. On both tails shafts...
    May 2016
    8 Post(s)
    weel just had a crawl under my patrol and have the bolt in my hand … 12mm fine thread flanged head and nut 17mm across the flat
    bolt fixes 37mm underside head to end of thread and.... shank 12.5mmdia 17mm long ..
    So there is no bolt head markings ! cant get to the hardness tester its busy here .. but don't think a standard bolt will work well .
  8. The Following 3 Users Say Thank You to Tip12345 For This Useful Post:
    Cuppa (15th October 2020), MudRunnerTD (15th October 2020), mudski (15th October 2020)
  9. #6
    461 Post(s)
    Yeah just check a pic of the genuine bolt from the parts catalogue. yep tiny step in it. Hence me not remembering. I wouldn't bother with new bolts personally unless they are rooted. Bit of loctite on the threads and away you go.
  10. #7
    May 2016
    8 Post(s)
    good I will crawl back under and replace the bolt ! before I go home
  11. The Following User Says Thank You to Tip12345 For This Useful Post:
  12. #8
    461 Post(s)
    Haha! Yeah don't forget to put that back in.
  13. #9
    Sep 2015
    Yes, took in a sample, but they don't stock grade 8 M12 with flange and shank. The bolts look ok, but the nuts are shot. Does anyone know a good online supplier?
  14. #10
    Sep 2015
    Thanks for your trouble. I did find the specifications on the net and it is grade 8.
