12th July 2011, 01:18 PM
tb42 to td42 engine conversion wiring loom
hi all. just doing a tb42 to a td42 engine conversion. just wondering if there is much difference in looms between the two. would a simple "push button" for the glow plugs be all that i need to change or is there more to it than what i'm reading in posts.
thanks heaps in advance
rod white
12th July 2011 01:18 PM
12th July 2011, 03:01 PM
I don't know if there is a difference between the petrol and diesel wiring looms.
If you were wanting to keep things simple then you could do as you suggested and run the glow plugs off a very simple circuit with a momentary push button switch. Being a high current circuit you would need a relay and obviously the circuit would also need a fuse.
The factory glow control unit is basically a timer with a coolant temp sensor input so it can adjust the glow time to suit engine temperature. It still operates a relay to activate the glow plugs.
Tony
16th January 2014, 07:16 AM
this is very helpful info doing this at the moment
24th January 2014, 11:23 PM
hadleecap
vehicletracking
Hi, just followed these simple engine conversion pinpoints and found them terrific.
Thanks for sharing this useful info
Hay guys. We ask all New members to Jump over to the intro section and put up a thread. Bit of a hand shake.
