19th September 2020, 03:01 PM
Cruise control pinout td42
Hi all,
Anyone have or know where I can find a pin out/wiring diagram for the cruise control unit on a GU3 td4.2?
I had a bit of a dig through the old posts but I couldn't find one.
I think I'll be able to work out what I need to without one, just might save me a bit of time.
19th September 2020 03:01 PM
20th September 2020, 10:15 AM
if you ever find it, can you flick me a copy, as I want to put CC onto my '99 DX
20th September 2020, 10:59 PM
The post I put up about fitting steering wheel audio controls has some reference pages from the workshop manual that show the cruise control buttons wiring.
http://www.nissanpatrol.com.au/forum...d.php?p=787897
Have a look at pages EL48 and EL163 and the M28 pin configuration.
Is that what you are looking for?
The Following 2 Users Say Thank You to Cremulator For This Useful Post:
0-TJ-0 (21st September 2020), Bigcol (21st September 2020)
21st September 2020, 07:18 AM
so you want the speedo wireing ? I don't think the TD 42 has the smarts . its the very basic system on these old gals .
Cruse control is a lot of work . Will follow this thread as I have been looking for an easy way out to do this
21st September 2020, 12:31 PM
Thanks all, and thanks @Cremulator . I've had issues navigating that WSM in the past but got it worked out and found what is looking for.
When I work out the best way to fix my issue I'll definitely post it here. It doesn't appear common, but might help someone.
Cremulator (21st September 2020)
21st September 2020, 01:02 PM
I have a autron CC thats not working , can anyone tell me where it is and Ill trace wires from there
TIA TD
21st September 2020, 01:20 PM
The factory unit is in the driver's side foot well kick panel.
