Results 1 to 7 of 7
Thread: Cruise control pinout td42
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Hi all,
    Anyone have or know where I can find a pin out/wiring diagram for the cruise control unit on a GU3 td4.2?
    I had a bit of a dig through the old posts but I couldn't find one.
    I think I'll be able to work out what I need to without one, just might save me a bit of time.
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    if you ever find it, can you flick me a copy, as I want to put CC onto my '99 DX
    Jun 2018
    24 Post(s)
    The post I put up about fitting steering wheel audio controls has some reference pages from the workshop manual that show the cruise control buttons wiring.
    http://www.nissanpatrol.com.au/forum...d.php?p=787897
    Have a look at pages EL48 and EL163 and the M28 pin configuration.
    Is that what you are looking for?
  5. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    0-TJ-0 (21st September 2020), Bigcol (21st September 2020)
    May 2016
    8 Post(s)
    so you want the speedo wireing ? I don't think the TD 42 has the smarts . its the very basic system on these old gals .
    Cruse control is a lot of work . Will follow this thread as I have been looking for an easy way out to do this
    Jan 2017
    South Australia
    11 Post(s)
    Thanks all, and thanks @Cremulator . I've had issues navigating that WSM in the past but got it worked out and found what is looking for.
    When I work out the best way to fix my issue I'll definitely post it here. It doesn't appear common, but might help someone.
  8. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    Cremulator (21st September 2020)
  9. #6
    I have a autron CC thats not working , can anyone tell me where it is and Ill trace wires from there
    TIA TD
  10. #7
    Jan 2017
    South Australia
    11 Post(s)
    The factory unit is in the driver's side foot well kick panel.
