Page 28 of 45 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 444
Thread: Weekend projects
  1. #271
    192 Post(s)
    Bloody awesome Nicko absolute machine. . Love how it's built over the old one, how did you do the floors so they match up or slab over top of old one??
    Everything from the old shed will move once it's weatherproof. At the moment it's just away from the edges where it was most likely to leak. Once it's fully sealed I'll start moving the benches. Going to be a process but I'll get there. Re floors the slab was originally poured at around 4x11(11m was max width for the space and I came out 4m from the garage next door) only one end is square hence the hip at one end. The old shed was just a pre-made second hand jobbie, The new shed is made to completely take up the slab, no need to change flooring
  4. The Following User Says Thank You to rusty_nail For This Useful Post:
    Rossco (16th April 2022)
  5. #273
    109 Post(s)
    The walls do you mean? It's jammed tight inbetween a retaining wall and a handrail(3x100x200 posts) and the trusses hold the walls plumb. The are diagonal braces in the roof the hold it level and the tophats used as bearers are spacing the trusses correctly.
    Fair enough mate. At least the weatherboards will help. Are you structurally independant from next door's garage?
  6. The Following User Says Thank You to Plasnart For This Useful Post:
    rusty_nail (16th April 2022)
  7. #274
    Ooi do you mean hoop iron or something similar? Daz mentioned the same but it really can't move anywhere I want able to square the walls up, just built them level off the top retaining wall, then jammed the last frame in. I can't see it being able to shift left or right and the roof trusses hold the ins and outs. I mean at the end of the day, it's a shed, made from f14 grade timber, it's ridiculously overkill lol. Should be fine. I appreciate the mention though. The external cladding will hold the walls, but the internal walls will be fixed with 16mm ply also, once both sides are fixed on I don't think anything will move anywhere.
  8. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
    MB (16th April 2022), Plasnart (16th April 2022)
  9. #275
    472 Post(s)
    Another day another early root lol. Only fiddly roof bits left tomorrow
    Champion Effort Nicco Mate, Looks Tops
    See what happens when you smash projects out, you get to score fiddly roof bits all over ya face
  11. #276
    109 Post(s)
    All good mate. Just would hate to see it fall on your head in a big blow which you get up there or if the neighbour pulls his garage down.
  12. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    MB (16th April 2022), rusty_nail (16th April 2022)
  13. #277
    Righto, I'll go get some tomorrow lol
  14. #278
    472 Post(s)
    FWIW: Not sure the Good Ol Boys in the Northern US of A even know what hooping iron is, all domestic structures throughout say Minnesota gales are stabilised via what we call Ply Board externally & internally
  15. The Following User Says Thank You to MB For This Useful Post:
  16. #279
    The roofs also right? All the American Reno shows look like they have ply on battens with shingles onto lol
  17. #280
    472 Post(s)
    Aint nothing strong enough in your neck of the woods to stop a 100’ Messmate coming through the top. May I kindly suggest Stihl and or Husky
  18. The Following User Says Thank You to MB For This Useful Post:
