Results 1 to 10 of 17
Thread: Central locking 2012 GU Y61
    Jun 2016
    PERTH
    G'day..problem i have is, after a drive i push the lock button on the key fob and nothing happens so i lock the door manually with the key...after a day at work i can unlock and lock the doors with the key fob?? got me beet... have changed the battery in the key fob...any ideas on a fix appreciated
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Quote Originally Posted by bronk View Post
    I've got the same model Patrol and never had an issue. I bought it new and haven't changed the batterier in either fob. Have you tried the second fob?
    Jack
    109 Post(s)
    I gave up on my fob years ago. Replaced batteries, helped for a bit, then problems again. I just use the key. No biggy for me. Couldnt be stuffed working through the fob issues. Probably a chinese accessory.
  5. The Following User Says Thank You to Plasnart For This Useful Post:
    bronk (9th September 2020)
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I had similar issues. I just replaced the receiver unit with an after market one which was like night and day. Cost about an hour or two and whatever the unit itself was worth.
    I remember reading someone on here re-did or added earth straps between body and chassis chasing another issue and they noticed it improved the central locking as a side benefit.. Maybe it was @Cremulator .. But I can't remember
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Replace it with a Jaycar remote circuit. Cheap and easy to do. There is a thread on here that explains how to do it.
    Jun 2018
    24 Post(s)
    Yes, it was me. I added an underbody earth strap for my sub tank issues and it improved the range that the factory central locking worked from, but it was short lived. It's gone back to working from close range only again.
  9. The Following User Says Thank You to Cremulator For This Useful Post:
  10. #7
    Jun 2016
    PERTH
    Hi Jack...no not yet..but good idea..cheers
  11. #8
    Jun 2016
    PERTH
    Cheers Guru...will have a look into it
  12. #9
    Jun 2016
    PERTH
    Ok will sus it out..thank you BillGU
  13. #10
    Jul 2010
    Thurgoona
    7 Post(s)
    This is the thread I was thinking of. It has lots of information. I used the Jaycar module and it works fine - every time!
    http://www.nissanpatrol.com.au/forum...entral+locking
  14. The Following 2 Users Say Thank You to BillsGU For This Useful Post:
    bronk (9th September 2020), pollenface (13th November 2020)
