Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: GU 2009 Second Battery Tray with Catch Can
    Jul 2020
    Central Queensland
    Fireblade - What tray did you use?
    Sep 2018
    queensland
    i dont know the brand i got it 2nd hand i fits a full size n70zz battery though
  4. #13
    Aug 2011
    River Heads Q
    4 Post(s)
    My son just moved 2nd battery from under bonnet to under tray on his 2005 Tdi as the heat kept cooking battery.
    I have had mine under tray from almost new and no problems.
    Also, future types of batteries coming on the market may not like heat as well.
  5. #14
    472 Post(s)
    ARB GU second battery tray on my shed queen ute can’t complain
    Running possibly the hottest engine variant in any Patrol (6.5 Chev) and my Optima yellow tops have performed same same tops as previous play TD42 kettle utes :-)
    Expensive but never appear to fail across many including twin yellows in the old family GU touring truckster
    Fast to recharge is Key
  6. #15
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    X2 ARB with @MB aux tray(old family GU touring truckster), be same me (adjacent to CRD Alternator). Handles many corrugations, our home road is full with them, does the job well (180,000 ks since new) and only ever used sealed FLA no overheat issues(3rd battery in 12 yrs). Also prefer to run electric winch off aux battery, so best to keep cable runs to a minimum to reduce voltage drop (just depends what you want)..Would stay clear of batteries that do not cope with heat anyway.
    Many places to put CC, only imagination required and think of future mods track as said previously. Even had it under air intake duct @ airbox to turbo with Jonny Tig 600x300x76mm TM cooler fitted (1st image)_have the bracket if any one wants it.
    CC now adjacent to turbo with current install of 9" pod type airbox with PDI FM cooler installed (2nd image).
