21st April 2018, 04:24 AM
heater/AC doesnt work
Hello everybody. At first sorry for any mistakes. Im not from Australia.
I have problem with A/C Panel. It seems like doesnt work at all. A reaction is so delayed or there is nothing. When i press AC button, a compressor doesnt start. When i select the highest temp - there is no wam air from wents. Its stay like before but it switch on the screen. At last - when i select vent for screen/floor etc there is no reaction too. Only switch on the screen. What can i do? Thanks for any help!
21st April 2018 04:24 AM
21st April 2018, 09:13 AM
I am he, fear me
Hi Mate,
What year and model is your vehicle?
How long have you owned the vehicle?
Has the fault always been there... or did it happen gradually... or was everything working and then it stopped?
A/C could simply be a blown fuse or need a regas
Air direction could simply be a slipped cable and it is stuck on "screen"
21st April 2018, 10:38 AM
Finer,
Was it working and now stopped working, or have you purchased a new vehicle and it has never worked since you have owned it?
21st April 2018, 10:33 PM
My vehicle is from 1998. Its worked well. But 2 or 3 weeks ago I had problem with no heater. But when I unplugged battery for a night, next day it worked fine. Few days ago I found a problem which I wrote before. I was looking for a fuses but all are fine. I don't know what's exactly the problem or where I can find and solve it
22nd April 2018, 11:47 PM
If it is a known vehicle, and it has just started not working, it will usually be one fault - not two or more.
It also seems like you may have the Climate Control Panel rather than the Conventional AC Controls.
I would look at things like trying a known working Climate Control Unit, as you may have a dry solder joint within your unit
