Results 1 to 10 of 19
Thread: Upsized Reverse Lights
    Dec 2017
    NE Melbourne
    I've mounted a reverse camera but I need some additional light for reversing up to the boat on those pre-dawn outings (currently I get a torch with a magnet out of the shed and attach it to the factory tow hook below the doors). I've just seen these lights which are reasonably priced and look small enough that I think I might be able to mount them in the factory rear bumper. Has anybody done this? My main concern is that the plastic might not be strong enough but I think if I put in some kind of metal backing then it will probably be OK.
    https://www.stedi.com.au/10w-mini-le...unt-osram.html
    Keen to know if anybody had mounted these or similar??
    Gags
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I have 2 little cheap 20w (4LEDs each) on a bracket behind my spare wheel
    ideal for reversing at night, and / or setting up camp at night
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    i put a 6 inch light bar under my spare tyre, worked well just need to be a little careful putting the spare back
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Need to be a little careful with 'reversing' lights. I believe they may need to NOT be activated by selecting reverse and NOT from the drivers seat depending on what they are, where they are, and where you are. ADRs and state laws may apply.
    Patrol Guru TimE's Avatar
    Canberra
    I run a pair of these 27w leds, cost bugger all and provide plenty of light. They are wired into the Patrols reverse light so only come on in reverse. Works for me.
    My OE reverse lights have 120 smd leds
    turn night into day
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    18w/6" led light bar here, wired to the "single left" reverse bulb
    2008 CRD Auto Wagon
    Dec 2017
    NE Melbourne
    These only draw half an amp and I measured it up today.....I am looking at removing the factory "recovery point" from under the rear doors, putting in 4 x grub screws to cover the holes, and then fitting two of these lights one above the other and wire them directly to my standard reverse light:
    https://www.stedi.com.au/surface-4-w...ck-lights.html
    I was thinking of putting a couple of the flush mount versions into the rear bumper bar but I think these surface mount ones will be easier (and cheaper!!)
  10. #9
    Expert 92GQ's Avatar
    Sep 2013
    Qld
    I have a frame that goes around the rear window for work lights. (first photo)
    I have an awesome led mounted under my jerry can box which is on the reverse light trigger. (second photo)
    The second photo also has my first go at a rear light bracket, the first photo has the second style of light frame.
    1992 TD42 GQ Patrol Wagon
    My GQ Build Page
  11. The Following User Says Thank You to 92GQ For This Useful Post:
    Big Gags (20th August 2020)
  12. #10
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    $20 for a pair on flea bay works good , used a 3 way switch so either on with reverse, off or on. Plus I used a relay
