7th August 2020, 02:48 PM
Y61 Patrol ZD30 manual drops out of first gear
I have a 2001 GU ZD30. The engine was recently rebuilt. Recently it's developed a malfunction in first gear in that the gear stick has become slightly sloppy and after putting it in first it simply drops out again. If I hold it in while I take off it's quite happy to stay there under load, and doesn't always drop out on over-run. It happens whether in two or four wheel drive, low and high ratio. It also feels a bit loose when moving to second, but it doesn't drop out of second. I think it's probably a problem with the detent spring, but I'm not familiar with Nissan transmissions. Has anyone had similar issues or know what might be amiss, and how to fix it?
Thanks,
Rayk
7th August 2020 02:48 PM
