Results 1 to 6 of 6
Thread: GQ Steel bar behind quater pannel in the way of Snorkel
    Advanced Dasa's Avatar
    Aug 2019
    North central VIC
    So I am unable to find any pictures of other snorkel installs with this in the way, has anyone seen this before and do I just cut through it as well?
    94 GQ coil cab TD42
    20150907_123122_zpsukkudzpu.jpg~original.jpg20150907_123106_zps75gcaxmj.jpg~original.jpg
    461 Post(s)
    Hack away brother. I seriously doubt it will be missed. Just remember. Measure twice, cut once.
    Jan 2018
    Pt Augusta SA
    When I installed mine last year I just cut through it. No damage has occurred in that area.
    Pete
    I assume you are trying to fit a larger snork through that same hole yeah? I cut slits arounf in and bent the tabs to make it bigger. There is not much room to work there. Cold chistle is your friend.
    Aug 2019
    North central VIC
    Thanks for the quick replies.
    Planing to use some scraps of 3" stainless I have laying around which will fit through the hole no problem once I hack that bar out of the way.
    Quote Originally Posted by Dasa View Post
    No probs. I went 4" through there on my GUIV. It will fit mate.
