Results 1 to 4 of 4
Thread: TD42 Oil feed from vac pump port passenger side
    Jun 2018
    Hello great people of the internet!
    I have a question regarding oil feed from what would usually feed the vac pump on the back of the alternator. As my vac pump in on back of the injector pump this port is currently blocked off with an allen head grub screw. (See attached)
    Is there any difference in flow rate or pressure compared to the port behind the engine mount where aftermarket turbos get plumbed into?
    Any comments will be much appreciated.
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    They would be feeding off the same oil gallery and the holes are both the same size so logically they would have the same flow/pressure.
    I have my vacuum pump on the alternator on the right side of the engine and I use the oil feed that was designed for the standalone vacuum pump under (not on the back of) the injection pump and it's been working correctly for the last 5 years.
    John
  4. The Following User Says Thank You to jff45 For This Useful Post:
    PeeBee (29th July 2020)
  5. #3
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    As far as I know...which aint much...you would have to upgrade your oil pump set to change/increase the flow...the ports would flow the same as explained before.
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  6. #4
    Jun 2018
    Cheers fellas.
    Not looking to upgrade flow or anything, just want to know if i can use the front one for turbo feed, no need to notch the engine mount unless required.
    Maby in the future use the other and return port for a bypass filter setup.
