Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: GU Door Striker Bolts won't budge
    Jul 2020
    Central Queensland
    Hi all.
    Bought new drivers door striker as my rubber covering was worn. Cannot get the bolts out. Have soaked them in Rostoff and used impact driver. No luck.
    Any ideas? Top bolt has some yellow paint mark on it. Unsure what that is for.
    Sep 2018
    queensland
    i used a screw driver from 4wd super center like the one bellow
    i pushed in so the tool wouldn't slip while also using a spanner on the end to get alot more force to turn it.
    this method has served me well for many cars not just patrols
  5. The Following 4 Users Say Thank You to rusty_nail For This Useful Post:
    Cremulator (26th July 2020), PeeBee (25th July 2020), Rossco (24th July 2020), threedogs (1st September 2020)
    192 Post(s)
    Try giving the screwdriver a good wack first quite often does the trick. . They can be a bugger those stricker plate ones. .
    194 Post(s)
    Use an impact screwdriver, the one with the hardened bits and you strike with a hammer - works very reliably
    462 Post(s)
    Yep! Works wonders for those screws.
    Yeah he actually states he had tried an Impact Driver already. If that ain't working then no screwdriver will sort it.
    I'm thinking an EasyOut mate. Drill it and easy out for the win. You might end up having to drill and retap at worst.
  10. #8
    194 Post(s)
    OK, missed that. Think your approach is right since the impact unit didn't work
  11. #9
    192 Post(s)
    I'd try welding a nut on if nothing else works, never had much luck with easy outs on things that are stuck firm. . Most wrongly named product ever lol
  12. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MudRunnerTD (25th July 2020), PeeBee (25th July 2020)
  13. #10
    462 Post(s)
    I remember removing those screws on my old 01' Patrol for the first time with the impact screw driver. I have to hit them hard, really hard. They did release in the end. Persistence is the key with these screws...
