Anyone know how much oil the 4 speed auto takes on an '08 CRD. It's not in the book( neither are the diffs or transfer capacities)
Also, does the transmission oil have to be changed at 40k service. The book states it does only on commercial vehicles and under harsh(towing,muddy, dusty rough) conditions .
I thought it's a must so I'm going to change it anyway but thought I might be able to clarify
Kris
Kris
Have you downloaded the GU manual Andy posted in the DIY section I recon it would have the info you require in that.
As for when to change it? I would recommend to follow the commercial vehicles guide lines as our 4bys do work hard just dragging there own big fat ass around not to mention what else we do in them....lol
I did look at Andy's manual but its written around the European spec vehicle. Not even sure for which motor as the engine oil capacities are very different to the ones in the Australian maintenance book. There is no reference to the auto transmition either.
Most of the downloaded manuals don't have the CRD 2007+ reference
Hi guys try these links.
If you go to the site below then click on the 4wd/Light Commercial Link you'll get the recommended Caltex lubricants for all parts. Other oil companies may have a similar set up. http://www.caltex.com.au/ProductsAnd...OilFinder.aspx
Kris
Hey Kris
Here's a useful website link. Put in all your info and it should tell u what bits and pieces are needed to be done for the service.
If you have any questions, ask somebody more knowledgeable than me! lol
