Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: '08 CRD 4 speed auto oil capacity and 40k service
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Anyone know how much oil the 4 speed auto takes on an '08 CRD. It's not in the book( neither are the diffs or transfer capacities)
    Also, does the transmission oil have to be changed at 40k service. The book states it does only on commercial vehicles and under harsh(towing,muddy, dusty rough) conditions .
    I thought it's a must so I'm going to change it anyway but thought I might be able to clarify
    Kris
    ________________________
    ______ 2017 D-Max _______
    Banned
    Quote Originally Posted by NissPat View Post
    Kris
    Have you downloaded the GU manual Andy posted in the DIY section I recon it would have the info you require in that.
    As for when to change it? I would recommend to follow the commercial vehicles guide lines as our 4bys do work hard just dragging there own big fat ass around not to mention what else we do in them....lol
    ACT
    I did look at Andy's manual but its written around the European spec vehicle. Not even sure for which motor as the engine oil capacities are very different to the ones in the Australian maintenance book. There is no reference to the auto transmition either.
    Most of the downloaded manuals don't have the CRD 2007+ reference
    I will change the oil anyway.
    Attached is a scan from my maintenance book.
    Kris
    Attached Files Attached Files
    Advanced Minx's Avatar
    http://www.datateck.com.au/lube/bp_au/
    This may help Kris. Just found it before but it could be handy for anyone else.
    If you's like it then you can put it in an appropriate thread if you think its worth it.
  6. #5
    ACT
    Quote Originally Posted by Minx View Post
    Mate, that's a great site.
    Now I know it's 11.8 liters...wow
  7. #6
    Banned
    Nice one Minxy thats just handy full stop..... post it up in the useful web sites thread as Im sure others will find it handy to...
    Paul
  8. #7
    Its a little ripper site isnt it.
    Save that one on your favourites for sure. my favourites list is almost maxed out after reading the info on this site...hehe
  9. #8
    Beginner Ducks's Avatar
    Aug 2010
    Pilbara WA
    Hi guys try these links.
    If you go to the site below then click on the 4wd/Light Commercial Link you'll get the recommended Caltex lubricants for all parts. Other oil companies may have a similar set up.
    http://www.caltex.com.au/ProductsAnd...OilFinder.aspx
    Also heres the castrol site
    http://www.datateck.com.au/lube/castr_au/default.asp
    enter in your vehicle and engine and you should get a rough capacity guide.
    Hope this helps
    Own 2000 GU ST Auto Patrol,Fitted with NADS (Nissan Anti Destruct Devices) Boost and Pyro Guages,33,2" lift
  10. #9
    ACT
    Cool, thank Ducks.
    That second link "datatek" is the same as Minx's link but Castrol....thats handy to know you can select different brands
  11. #10
    WA Wheatbelt
    23 Post(s)
    Kris
    Hey Kris
    Here's a useful website link. Put in all your info and it should tell u what bits and pieces are needed to be done for the service.
    If you have any questions, ask somebody more knowledgeable than me! lol
    http://www.carservice.com.au/car-ser...g-guide-2.aspx
    Ross
