21st July 2020, 05:11 PM
ZD30 intercooler
Hi all. Just wondering if someone could tell me how hard it is to change the intercooler on a 2006 3.0lt. I’ve misplaced my Haynes manual so I’m just wondering if it’s just remove and replace of is there more involved than that ?
Thanks in advance
Graham
21st July 2020 05:11 PM
21st July 2020, 05:20 PM
Should take less than a stubbie to remove and refit. Two hose clamps, unclip a sensor and four bolts....
The Following 2 Users Say Thank You to mudski For This Useful Post:
0-TJ-0 (21st July 2020), Oddie1969 (21st July 2020)
21st July 2020, 05:25 PM
mudski
Right, that sounds like something even I might be able to manage, thanks 👍
21st July 2020, 09:01 PM
I don't know a screwdriver from a spanner and I got it done on my own.
I did leave a blanking bolt out but got that sorted quickly
The Following User Says Thank You to Mc4by For This Useful Post:
21st July 2020, 10:39 PM
Mc4by
Ha ha. 🤣 Mine is leaking a lot of oil so I wasn’t sure if there were oil lines that needed to be considered, after a bit more reading it looks like that may be coming though with the air.
22nd July 2020, 10:54 AM
When you say "fitting a new one" are you talking original or aftermarket? Some of the aftermarket ones (like the one I purchased years ago) are a pain to fit. Most Patrol owners these days get the original IC modified by getting the core removed and a more efficient core TIG welded in its place. This gives you better cooling of air plus it wont leak AND it is guaranteed to fit.
22nd July 2020, 12:25 PM
Oddie1969
Yep, do you have a catch can fitted?
I live in the "don't know a screwdriver from a spanner" drawer as well plus I specialise in forgetting things, but the oil will be coming from your PCV blowing back into your air inlet. The catch can goes a fair way towards removing that oil. Please someone correct me if I'm wrong.
There's not meant to be oil in the IC, just wind.
22nd July 2020, 02:32 PM
#8
easy enough to change once the engine cover is removed.
Not sure on prices but a change over IC fully tigged will
be approx 33% bigger
23rd July 2020, 09:44 AM
#9
BillsGU
Aftermarket direct swap. Welded instead of crimped but all the same dimensions. All done, went in like a dream.
23rd July 2020, 09:49 AM
#10
10G
Ha ha, we sound like twins !
No I don’t have a catch can, I was reading about those, are they worth it ? Do I need to be cleaning anything else so the intercooler doesn’t get clogged up again ?
Reason: Spelling
