Results 1 to 8 of 8
Thread: Brake Proportioning Valve Bracket
    Gday again.
    I’ve just bought a brake proportioning valve bracket kit from Roadrunner Offroad to offset the raising of the brake valve bias now I’ve got a 2” lift in.
    The bracket has two offsets - One set of holes for a 50mm lift (2”) and one for 70mm lift (3”).
    Can i “SAFELY” (haha) use the 3”/70mm holes having a 2” lift so that it adds a bit more braking to the rear brakes (as I know the rears don’t do much work apparently from reading up on them)?
    465 Post(s)
    bolt it up and try it. Stock Patrol brakes a shit regardless. Worst will happen is you will lock the rears up in the wet and fish tail down the road into oncoming traffic.
    Sep 2018
    queensland
    i put a bracket on my patrol and the brakes started to squeak, so i ended up not using it.
    465 Post(s)
    Quote Originally Posted by Fireblade View Post
    Did you bleed your brakes after installing the bracket?
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    When you bleed your brakes don't forget to bleed the proportioning valve (bleed nipple can be a bugger to get at, especially if the car is not on a hoist). Many people (and mechanics) don't - and this adds to the crappy brake effect, plus the valve builds up moisture and crud over a period of time and does not work correctly or sometimes - doesn't work at all.
    It’s a TB42s. They don’t go fast enough to fishtail into oncoming traffic and lock brakes 🤣 Need a km long run up to get to 80kph, using all of those 40rwkw 😎 Mind you i can totally drag off forklifts and tractors easily.
    465 Post(s)
    And that too. Bleed that before bleeding the rear calipers aswell.
    Sep 2018
    queensland
    i didn't do that, so the bleed order is to to the brake valve first then the 4 calipers.
    i learn something new every day
