Results 1 to 10 of 10
Thread: Fog lights
    Expert Mickhead's Avatar
    Oct 2019
    Fog lights
    Hi all. Has anyone out there cut holes into their standard alloy gu 3 bullbar to fit fog lights?
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by Mickhead View Post
    You mean drill holes, not cut ... anyway I Forget Fog lights, just install a good size light bar, not a baby one on your bullbar. Good to see all the road, not kms up the road lol regards Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  4. The Following 2 Users Say Thank You to altech For This Useful Post:
    GregRT (27th August 2020), Mickhead (22nd July 2020)
    Quote Originally Posted by altech View Post
    far out! when you post you make it count mate! been a long time since reading you bud!
  6. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
    altech (23rd July 2020), mudski (22nd July 2020)
  7. #4
    Oct 2019
    Cheers Alex but you missed the "fog" bit. Have plenty of light coming out the front, but need a bit of low and wide light to go with the low beams to illuminate the edges of the road close by when the weather turns to shyt. Something I can use with oncoming traffic....
    Most of the bumper mounted fog lights I am seeing require a square or rectangular hole so drilling might not work.
  8. #5
    461 Post(s)
    Haha! I was just thinking the exact same thing.
  10. #6
    Assuming you are going to run a round fog then a hole saw would be the go for sure mate. an Alloy bar would take little effort for a decent hole saw and just find the light you want, keep it smallish then buy a hole saw the right size.
  11. #7
    Nov 2011
    Rupanyup, 3388, VIC
    Really Guys, I have always been here ...... thanks for the love LOL
  12. #8
    Aug 2020
    Really sounds like a light bar is way better than fog lights. We'll be working on the Patrol next after we finished installing the parts from 4Wheelonline onto the Jeep project. Will definitely consider a light bar.
  13. #9
    May 2016
    lower west victoria
    30 Post(s)
    Hey aren't fog (yellow) lights illegal now??? Driving lights, like those small, normal light, lights usually under the bumper are OK.
    A mate told me a trick when cutting ally. Spray WD40, CRC etc where you're going to cut, makes it like a hot knife through butter.
  14. #10
    Jul 2018
    I replaced the "fog/driving" lights on the factory trol steel bar that were quoted as $450+ from Nissan with a $160 pair from Stedi ... OMG the difference .. there is more light from these 2 little suckers than the low beam and it's low and wide .. defo worth a shot. i know what ya mean as well. Tracks, trails and the beach it's nice to have that low and wide spread. I have the big lightbar up top for a bigger field of view but the little fogs work a treat
