18th July 2020, 11:17 PM
#21
A bit of a different brand but iv been running sailun terramax (yes they’re Chinese). Probably won’t use them again as I’m after something a bit more aggressive but iv done 60k and still around 35% tread. Rotated every 10000, no punctures at all. No slips in the wet and have been very reasonable off road. At $130 a tyre I’m not complaining!
2006 4.2 tdi wagon
TJM BullBar and bar work, Light bar & spotlights, Airtech snorkel, tradie rack, blocked egr, 2inch lift on 33s and a 3 inch exhaust to go with it all.
Plenty more to come!
18th July 2020 11:17 PM
19th July 2020, 11:54 AM
#22
MB
Upon reflection, these great Nitto’s look and feel exactly the same as they were when new bought upon leaving our N/E Victorian healthy farm many months ago :-(
Totally agree about the Nittos, I've done 60,000 on a set, expect another 5000kms at least.
The Following User Says Thank You to 10G For This Useful Post:
19th July 2020, 11:11 PM
#23
They are goodens 10G mate!
Not so sure they’d excell in the serious mud crud due to their circumference sidewalls mold line hindering release and their hardness I haven’t had the opportunity as yet to sub 20psi their flexinessy :-)
Do honourably rate them so far as the best highway / M/T bang for buck I’ve known in a short 20 say years :-)
13th August 2020, 05:44 PM
#24
So both dualers and BFG are out of stock australia wide apparently.
Ive been told the yokohama geolandar at go15 are good for my mostly road and occasional beach/dirt driving...thoughts?
14th August 2020, 09:29 AM
#25
A_Millsy
I've not seen Yokohama's used on any 4WD since I got into the scene in the late 80's. They used to be known as pretty soft tyres and not too puncture resistant, but that's from quite a while ago.
14th August 2020, 11:18 AM
#26
Moderator
To be honest mate i would be chasing a second set of tyres. You will find someone selling their road tyres cheap because they want to go muddies. Grab them cheap. you will probably get a full set on rims at a good price. Ex factory. Grab a second hand set of muddies on steelies or something and leave them in the shed and they will last you 10 years mate. If you have the room to store them then you can swap them over in an hour and then play hard without compromise then put the hwy tyres on for your commute without the noise of a Muddie or even an AT.
Check out my Toy -->
Rogue Dung Beetle
Lionel84 (16th August 2020)
14th August 2020, 11:26 AM
#27
Funny you mention that, Darren. I have a set of 31" HT tyres lying about in my shed. I am quite happy to give them to anybody who wants them. Three are in really good nick and have good tread, one has the same but has had a puncture repair, and the spare is a different brand, but still has good tread. The only issue with them is that they have been sitting around for a few years.
16th August 2020, 11:47 AM
#28
I had a set of old BFG A/T (KO 1's I think they were). Not too bad, and ran them out. A bit of a pig on the road, and offroad were fine, but lacking due to degraded tread.
Got a set of BFG A/T KO 2's. Amazing softer feel on the road, very stable, grippy and comfortable.
Took them up the Old Telegraph Track to the tip with no issues. Good grip on the sidewalls too, but didn't fare well in deep mud, after wankers in big lift utes with muddies chewed it all up, instead of driving over sensibly, and buggered the track up.
2007 Nissan Patrol Y61 Wagon AT 2009 ZD30CRD Engine
Snorkel, Tillex, HPD Intercooler, 3" King Brown Exhaust, 2" Bilstein Lift, Steel Bar and 12000lb Winch, Engine Bay Lighting
16th August 2020, 12:13 PM
#29
For what it’s worth I run Kumho MT 51s & swear by em , you have to rotate regularly otherwise they wear unevenly but their grip off rd is unreal.
17th August 2020, 08:24 AM
#30
I had no problems with a set of Coopers AT3's ... did 80,000kms and the car died before the tyres did.
2008 CRD Auto Wagon
